Oil Filter Popped Off - Too High Pressure?
tuning, repairs, servicing & maintenance
Postby Zeemax_Mini » Tue 13th Jun 2006, 06:26pm
Well driving along yesterday suddenly the oil pressure light came on...not a good sign! So I pulled over straight away and sure enough it had dumped all its oil. I left it overnight thinking the worst, but went back this morning and the oil filter had come completely lose and lost the oil through there. So I did it up and re-filled with oil, then restarted the engine. Started normally, oil pressure light went off....then I heard a pop and it had popped the oil filter off and dropped the oil again! I bought a new oil filter and this time it didnt pop off, have driven it about 50 miles home and it didnt come of or anything in that time. But the threads on the old one dont look stripped, and as its a brand new engine the filter has only been on for about 100 miles! What could have caused it to pop off!? Thanks, Dom
Zeemax_Mini
Has thanked: 0 time
Been thanked: 0 time
RE: Oil Filter Popped Off - Too High Pressure?
Postby theminiofv » Tue 13th Jun 2006, 06:33pm
hmmm
theminiofv
Has thanked: 0 time
Postby RikWalsh » Tue 13th Jun 2006, 06:36pm
what was the o-ring seal like on the old filter?.. did it drop off completely? :-k ive seen similar before, but not on a mini.
Rik
User avatar
RikWalsh
Has thanked: 1 time
Been thanked: 3 times
Tag Line: Ignore my posts - I'm sober.. E.A.P.B.A.M
Drives: 998 Mini - Joc,
1293 Clubby, BMW E91 320i (LCI)
Postby Zeemax_Mini » Tue 13th Jun 2006, 06:44pm
The o-ring looked fine! When I heard the pop it hadnt completely come off, just become really loose! Dom
Zeemax_Mini
Has thanked: 0 time
Postby retro_10s » Tue 13th Jun 2006, 06:46pm
sounds strange... could it be something to do with the little spring loaded ball that sits on the bit you screw the filter to?
User avatar
retro_10s
Has thanked: 0 time
Postby Zeemax_Mini » Tue 13th Jun 2006, 06:50pm
Hmm i havent noticed a spring loaded ball but Ill have a look! The weird thing is is that the old filter doesnt even look like it has a stripped thread, yet it definitely popped off and the new one didnt! Dom
Zeemax_Mini
Has thanked: 0 time
Postby retro_10s » Tue 13th Jun 2006, 06:56pm
are the threads on the filter housing stripped?.... the ball sits in the housing, you'll have to look under the car and up into the filter housing to see it.... so it could be messy. I think it's the filter bypass, basically if the filter gets clogged then the pressure pushes the ball up and allows oil circulation...... as unfiltered oil is stil better than no oil.
it' just unlikely it's seized though as it sits in oil!!!! grrrrr, I'm really not sure.
User avatar
retro_10s
Has thanked: 0 time
Postby Zeemax_Mini » Tue 13th Jun 2006, 07:04pm
The threads on the filter housing look fine actually...but the weird thing is that the ones on the oil filter dont look too bad either! If it 'popped' off rather than unscrewed...something must be stripped! If you see what im saying....if u can pull a nut off a bolt...it must be stripped! But it just doesnt look like it! Dom
Zeemax_Mini
Has thanked: 0 time
Postby keithyboy » Tue 13th Jun 2006, 10:59pm
If it was excess oil pressure it would be throwing it out of the breathers. I have heard of cars bursting the filter cannister to the oil pressure relief valve sticking (though I've never seen one) but I've never heard of one coming loose like that.
Had the can ballooned up at all?
User avatar
keithyboy
Has thanked: 0 time
Postby Zeemax_Mini » Tue 13th Jun 2006, 11:49pm
Nope! Can didnt look damaged in any way! Ive put a new one one and am carrying a spare new one in the car, so guess Ill just hope it was a dodgy one! Dom
Zeemax_Mini
Has thanked: 0 time
Postby GraemeC » Wed 14th Jun 2006, 08:42am
Might be a badly formed thread - afterall these things aren't a cut thread and are churned out by the million, if the machine had an off day it may be on the edge of production tolerences.
Was it 100% definately the correct filter?
User avatar
GraemeC
Has thanked: 0 time
Postby Zeemax_Mini » Wed 14th Jun 2006, 10:53am
Yeh fairly sure it was the right filter. Ill just have to hope it was a dodgy one I guess! Dom
Zeemax_Mini
Has thanked: 0 time
Postby ceejam » Wed 14th Jun 2006, 11:00am
Unipart GFE 166 or 443
Or Rover filter?
If not, it ain't the correct filter IMO!
User avatar
ceejam
Has thanked: 0 time
Postby Zeemax_Mini » Wed 14th Jun 2006, 12:36pm
Umm it was a champion one which popped off, the only one the shop had (Which is on it now) is by KFE or something....but i have 2 spares of Unipart which will be the next ones to go on in a few miles when I do an oil change. Dom
Zeemax_Mini
Has thanked: 0 time
Return to Mechanical
Users browsing this forum: Bing [Bot] and 32 guests
