Converting speedo??
restoration, welding, interior and exterior styling, paintwork, detailing, cleaning etc
Converting speedo??
Postby HondaPoweredChris » Sun 10th Feb 2008, 09:03pm
I am hopefully aiming to convert my boring rover speedo/dash to a centre console speedo but wondered how easy and how much it costs around about, and if it will run off original wiring etc. My speedo at the moment is standard on a 1996 equinox with no rev counter.
Any ideas people??
Regards miniEq/Chris
HondaPoweredChris
Tag Line: mmmmm beeer!
Drives: VW polo, E reg mini Mayfair project
RE: Converting speedo??
Postby Noll » Sun 10th Feb 2008, 09:06pm
minispares and minisport have a conversion wiring loom for the electrics, you can just move the speedo cable but im sure you have to modify the plate in the middle of the bulk head
Noll
Tag Line: -=Classics Never Die=-
Drives: 1982 1000HLE (project)
Postby HondaPoweredChris » Sun 10th Feb 2008, 09:20pm
How do you fit the wiring loom etc, would i be better getting my local auto elctrics to wire it in?
And how do you modify the bulkhead?... can you buy the part for it? and would it be bolt on or weld on.? Its just on a late injection mini you peel the dash away and theres TONS of wires every where. PLus it got the immobiliser light...
Seems theres more to it but i so want it as they look the part instead of standard boring stuff.
HondaPoweredChris
Postby NE-Matt » Sun 10th Feb 2008, 09:56pm
The conversion loom is just plug and play from what I remember. I had plans to do this to my '94 Tahiti but gave up when I found that there was more to it than met the eye!! The major stumbling block was mounting the centre pod to the later bulkhead and all it's wiring, I'd imagine theres more on an spi.
Not impossible, just will require thought and effort, which at the time I had neither!! :P
NE-Matt
Drives: Vauxhall Vivaro.......seriously........
Postby HondaPoweredChris » Tue 12th Feb 2008, 12:17am
so the old dash wiring plugs in the center speedo? plus i only want center speedo with fuel gauge and temp gauge and no oil pressure gauge as thats wat i got now but standard rover mini?
HondaPoweredChris
Postby NE-Matt » Tue 12th Feb 2008, 01:07am
The conversion wiring loom basically allows you to plug the cars wiring in one end and the other end into the centre setup.
NE-Matt
Postby ceejam » Tue 12th Feb 2008, 12:03pm
It's a fairly major job, but straightforward, even without the "conversion" loom.
I haven't done an injection car, but done a few 80s Minis. Bascially take the plateb OUT that covers the bulkhead hole, and bolt the centre binnacle in the same holes, then join all wires colour to colour!
ceejam
Postby HondaPoweredChris » Tue 12th Feb 2008, 08:07pm
sounds complicated ???????????????? it would cost so much if i asked my auto electrical place to do it and also because they probably haven't done anything like that for a while theres no telling how they might bodge it. :?
HondaPoweredChris
Postby ceejam » Wed 13th Feb 2008, 11:32am
Not complicated at all, but it IS time consuming, probably 3 or 4 hours work in total!
ceejam
Postby HondaPoweredChris » Wed 13th Feb 2008, 08:54pm
anyone got a simple step by step guide to guide me through it then
HondaPoweredChris
Postby HondaPoweredChris » Thu 14th Feb 2008, 03:48pm
I have seen in MOSS catalogue a conversion for £369.99 which inlcudes everything for the conversion this is quite abit so wanna really know how its done from you guys even though i think the kit comes with instructions..
Also how exactly, is the oil pressure gauge plumbed in??? Cause i think the 3 clock binnicle has an oil pressure gauge as well as temp gauge/ fuel gauge, which is basically what i got on standard clocks but instead of oil pressure gauge you get the warning light...
Any ideas then
HondaPoweredChris
Return to Bodywork
Users browsing this forum: No registered users and 18 guests
