Help Wheel Arches?!?!?!
restoration, welding, interior and exterior styling, paintwork, detailing, cleaning etc
Postby M1N1C00P1275 » Wed 6th Feb 2008, 03:19pm
:roll: PLease Help
I have got a 1991 Mini Cooper, I bought a set of sports pack wheel arches didnt realize i have got to modify the wing to fit them and have painted the wings,
i dont know if u do have to modify the wings for sure i read it on plminis becauase they were offering a template cutting guide for fitting sportspac wheel arches
if i do have to does any one KNow of any other arches that look simlar that i dont have to modify the wings to fit , also i will be fitting ultralite extremes 7x13s
so the two main questions
1Q have got to modify the wing to fit the sports pack arches ?
2Q does any one know of any other arches that look simlar and will cover my 7x13 and mean that dont have to modify the wings?
Any help greatly appreciated, thanks..... :roll: :D :cry:
M1N1C00P1275
RE: Help Wheel Arches?!?!?!
Postby Kodiac_Jack » Wed 6th Feb 2008, 05:14pm
Hi
You will have to modify the wings to fit those wheels anyway so unless you are going to go for different wheels as well I don't think alternative arches will help.
There are a few designs of arch you could look at that will cover the wheels like the miglia style ones, Grp5 or Grp 2 wide arches etc but like I said you will still have to cut the wings or those wheels will rub.
Chris
Kodiac_Jack
Postby M1N1C00P1275 » Thu 7th Feb 2008, 12:55am
[quote="Kodiac_Jack"]Hi
You will have to modify the wings to fit those wheels anyway so unless you are going to go for different wheels as well I donthanks chris could u tell me more on how i will need to cut the wings for my sportpack arches and 13 x 7 wheels would i get away with other wheels under the sptpck arches that wouldnt have to cut the wings
M1N1C00P1275
Postby Kodiac_Jack » Thu 7th Feb 2008, 01:07am
The wheels will rub as they are quite a lot wider than the standard wheels.
Anything 6 inches or wider will probably mean a certain amount of the wing will have to be trimmed.
Anything less than 6 or 7 inches will not be wide enough to fill Sportspack arches in my opinion.
The fact that you have painted the wings shouldn't be a problem as the area you will need to cut will be hidden by the arch.
Hope that helps
Chris
Kodiac_Jack
Postby M1N1C00P1275 » Thu 7th Feb 2008, 01:12am
[quote="Kodiac_Jack"]The wheels will rub as they are quite a lot wider than the standard wheels.
The fact that you have painted the wings shouldnthanks do u advise i get a cutting template and if so where from as pl mini are out of stock
M1N1C00P1275
Postby M1N1C00P1275 » Thu 7th Feb 2008, 01:38am
do i need a cutting template if so where from as pl are out of stock thanks
M1N1C00P1275
Postby M1N1C00P1275 » Thu 7th Feb 2008, 03:26am
thanks chris :shock: :o :D :) :P :draw: :drunk: :thumb: :hooked: :peace: :pirate: :brumbrum:
M1N1C00P1275
Postby adam_h » Thu 7th Feb 2008, 08:15pm
You can download the templates for free somewhere, I'll have look.
EDIT: On the minispares website, click on "downloads" on the top right and iirc there were free teplates in there once you had registered.
adam_h
Postby M1N1C00P1275 » Fri 8th Feb 2008, 02:12pm
cheers m8
M1N1C00P1275
Return to Bodywork
Users browsing this forum: No registered users and 18 guests
