Megajolt & Ignition maps
Postby Gilesy » Mon 19th Jun 2006, 06:53pm
Guys, I'm slowly building a pile of info and images for a megajolt article for the Tech section, and thought it'd be handy to have a database of maps and the spec of the engine's they're running with.
If any of you get a moment, it'd be really handy if you could get a screen shot of your map in the megajolt programmer, the map file itself, and as comprhensive a spec-list as possible.
Cheers dudes,
Giles
Gilesy
Tag Line: Tits like coconuts
Drives: around without a dizzy, looking for puggles.
RE: Megajolt & Ignition maps
Postby Zippyrude » Mon 19th Jun 2006, 07:02pm
there is gonna be loads of folk interested in knowing more about the mapping stuff
brilliant stuff gilesy.!
will it include a parts list for the mega build ?
Zippyrude
Has thanked: 2 times
Been thanked: 70 times
Tag Line: Help support Minifinity
paypal@minifinity.com
Drives: projects galore
Postby retro_10s » Mon 19th Jun 2006, 07:43pm
yup it will be a real addition ot the site mate! cant wait for this!
retro_10s
Postby bud666 » Mon 19th Jun 2006, 09:03pm
i'll be having my car setup in a few weeks so i'll post up my map then when its been adjusted properly. its all over the shop and 'safe' at the minute. i'm only running 20 degrees advance on boost.
bud666
Drives: 200hp clubman
Postby Gilesy » Mon 19th Jun 2006, 10:36pm
Yeah, I'm putting a list together of all the parts needed, and photographing the parts I have as I get them. So far I'm short of the VR sensor and trigger wheel, but I've found a Sierra in a local scrappy with them still fitted :-$
I won't go into the whole board populating thing - that's more than well enough covered on the MJ website, but I will try to cover opening up and de-pinning the ford connectors for rewiring/soldering, knocking up a home-made VRS bracket and the trigger wheel, mounting the coil pack etc.
When I first started looking into MJ it was a really unknown area to me, so I think a database of proven maps, and perhaps a set of "safe" maps to get people as far as the rolling road would make the whole proposition a little less alien to future noobs.
Gilesy
Postby retro_10s » Mon 19th Jun 2006, 11:03pm
am i right in thinking this allows you to have a mappable thingy on normal carbs?
retro_10s
Postby calumlorimer » Mon 19th Jun 2006, 11:29pm
you can have a mappable thingy but the whatdyamacallit has to be left standard.
Basically gives fully mappable ignition on the cheap with the possibilty of injection aswell.
calumlorimer
Re: RE: Megajolt & Ignition maps
Postby joeybaby83 » Tue 20th Jun 2006, 12:27am
calumlorimer wrote:you can have a mappable thingy but the whatdyamacallit has to be left standard.
whatdyamacallit?
megajolt just does ignition, megasquirt can do both ignition and fuelling.
joeybaby83
Postby calumlorimer » Tue 20th Jun 2006, 10:37am
retro_10s wrote: a mappable thingy
i was just taking the rhubarb
calumlorimer
RE: Re: RE: Megajolt & Ignition maps
Postby mini7racer » Tue 20th Jun 2006, 11:30am
will the maps be using a throttle position sensor or a vac sensor? as I will be needing a base map soonish for a warm 1293 but I will be using a vac sensor.
mini7racer
Tag Line: had 4 minis....now I have none
Drives: daily - Audi A4 2.0 TDi
weekend - mk2 golf 20vt
Postby bud666 » Tue 20th Jun 2006, 12:39pm
most people will go for a map sensor i think. i know mine is anyway.
bud666
Postby Brontoman » Tue 20th Jun 2006, 12:42pm
Thats what mine will have too.
Brontoman
Postby Gilesy » Tue 20th Jun 2006, 01:35pm
I'm using MAP too, but if the users of said maps specify what engine load sensing they run (MAP or TPS), it'll make it nice and clear.
Gilesy
Postby wil_h » Tue 20th Jun 2006, 01:46pm
What is the size of the mtrix on a megajolt? my megasquirt is 12x12 and I've got maps for an NA 998 and a turbo 998.
wil_h
Postby Gilesy » Tue 20th Jun 2006, 01:50pm
The NA 12x12 you sent me was really handy - I drew the 3d Map in CAD (geek mode) and used the mesh to create a 10x10 for the jolt with some sneaky spacing in the wider spreads towards the top third of the map where it was already a little spaced.
Gilesy
Postby wil_h » Tue 20th Jun 2006, 01:52pm
cool, I forget who I sent the map too, so many people.
wil_h
Postby UDO » Wed 21st Jun 2006, 11:27am
Theres some photos in my journal if they are any use
Have started doing this conversion recently, well aquiring parts and starting to wire things up, but not actually fitted yet
Will be using a TPS with mine thou, so depending on how long it takes you to do the article I may have a TPS map for you
UDO
Postby Gilesy » Wed 21st Jun 2006, 11:32am
Brilliant! Do you have info on making the throttle pot? That'd be really handy, meaning we can cover both side of the kit.
Gilesy
Postby UDO » Wed 21st Jun 2006, 01:01pm
Not done that bit yet but when I get round to it I will take some photos etc and let you have them to include in the article
No promise on dates though!
I know the TPS can come of a sierra or caviler about £3 from scrappy!
UDO
Postby Zippyrude » Wed 21st Jun 2006, 01:17pm
you lot are nutters :)
cant wait for this !
Zippyrude
Re: RE: Re: RE: Megajolt & Ignition maps
Postby Gilesy » Wed 21st Jun 2006, 01:32pm
Zippyrude wrote:you lot are nutters :)
And why? :lol: No more wet dizzys, dud points, caps or rotors, and almost free curve changes when the engine's altered. 8.)
Gilesy
Postby Zippyrude » Wed 21st Jun 2006, 01:38pm
and when i use your helpful knowledge to build mine i'll be offering beers all round to the authors for the hours of painstakinbg research you will have saved me having to do ;)
Zippyrude
RE: Re: RE: Re: RE: Megajolt & Ignition maps
Postby Gilesy » Wed 21st Jun 2006, 01:45pm
*Sneakily copied and pasted!* Can I have your autograph Zippy? Just sign here...
Gilesy
Postby stuminisprite » Wed 21st Jun 2006, 07:51pm
i have mine running megajolt on a map sensor. it can be tricky to fit in places but its definately worth it. anyone else noticed the motor will rev more freely and it runs a lot better.
one of the best mods for an a series i recon!!!
stuminisprite
Postby keithyboy » Thu 22nd Jun 2006, 08:20am
Gilesy wrote:Yeah, I'm putting a list together of all the parts needed, and photographing the parts I have as I get them. So far I'm short of the VR sensor and trigger wheel, but I've found a Sierra in a local scrappy with them still fitted :-$
I've got a Sierra on my drive with a trigger wheel. You could buy it then take the photo.
keithyboy
Postby Gilesy » Fri 23rd Jun 2006, 01:46pm
An update. I just plugged my USB/232 bridge and connected to the jolt, turned on the power supply and IT LIVES
How happy am I?! Even though I had to compromise on the odd component from what's specified, it works beautifully. I even trialled it by saving the basic map supplied and uploaded another. I'm reet chuffed, just need to solder in the MAP sensor and get the last few Dorf bits. I'm looking forward to this :lol:
Gilesy
Postby Brontoman » Fri 23rd Jun 2006, 06:51pm
Where are you getting the bits from Gilesy?
I have tried Alex a few times but he is not very quick to respond. I need the oscillator and map sensor + another couple of bits.
Brontoman
Postby Gilesy » Sat 22nd Jul 2006, 07:06pm
Guys,
If you would all be so kind, pleeeeease could you email me your map stuff to shadesofpoo<at>bodgetape.co.uk
I need:
Engine spec, particularly capacity, cam, CR, fuelling and breathing system and general head "spec".
Load sensing used, MAP or TPS
Map file (and info on which tuner program was used) and screenshot, preferably 10 x 10. I can convert it, but it takes a while so Id rather not if I can avoid it.
Thank you kindly,
Giles
Gilesy
Postby Brontoman » Sat 22nd Jul 2006, 07:24pm
Top plan Gilesy.
Brontoman
Postby Anton » Sat 22nd Jul 2006, 09:49pm
mines being setup on the rollers on the 1st remeind me and i'll post my map
Anton
Been thanked: 1 time
Tag Line: There is no such thing as a fast 998
Drives: Clubby Estate with 1380, Honda Prelude 2.2 Vti
Postby l_jonez » Mon 7th Aug 2006, 04:22pm
i have just read through this topic and its all very intresting and was just wondering if any 1 has made any progress with theirs?
im now thinking of going down this route with the 998 with 1275 head and phase 2/3 cam im going to be building.
l_jonez
Postby bud666 » Mon 7th Aug 2006, 05:36pm
i might throw my jolt on my thou this weekend if i get chance. Will take some pics and see if i can get a copy of whatever map i use.
bud666
Postby Anton » Mon 7th Aug 2006, 09:49pm
it will still be slow.....
Anton
Postby AlexF2003 » Mon 7th Aug 2006, 10:03pm
Brontoman wrote:Where are you getting the bits from Gilesy?
I have responded :?
What was your email addy and I'll double check!
Alex
AlexF2003
Postby AlexF2003 » Mon 7th Aug 2006, 10:04pm
BTW guys
Any old map will not be right for your engine. You need to get your car MAPPED!
Alex
AlexF2003
Postby bud666 » Tue 8th Aug 2006, 11:05am
yup i'd definately agree. i couldn't believe how much of a difference my jolt made with a dodgy home-made map, should be even better once its been properly mapped to suit.
bud666
Postby l_jonez » Tue 8th Aug 2006, 12:32pm
so would you guys say it was worth the time and money?
l_jonez
Postby Anton » Tue 8th Aug 2006, 12:49pm
HELL YES!!!!
Anton
Re: RE: Re: RE: Re: RE: Megajolt & Ignition maps
Postby Gilesy » Tue 8th Aug 2006, 01:04pm
l_jonez wrote:so would you guys say it was worth the time and money?
Only time that i'd normally be flitting away doing nothing anyway!
As for cost, I bought the board, box and processor, and built it up myself (using what bits I could scrounge from work), made a full wiring loom to connect everything together (again all scrounged from work) and I got all the Ford bits from one scrappy (if you're lucky you can get it all from on car!).
I've kept costs down wherever I can and it's come to about £65 so far. That includes all the components to populate the board too. All I need to do now is fit the Sierra trigger wheel to my spare crank damper (£5 of machining) and make up a bracket to hold the CPS.
That's about £70 all in for an infinate range of advance curves and no more damp problems, dicky caps and rotors and no moving parts to wear.
The 123 distributor is a work of genius, but will still always suffer the usual damp distributor problems, and they're about 200 quid.
Gilesy
RE: Re: RE: Re: RE: Re: RE: Megajolt & Ignition maps
Postby UDO » Tue 8th Aug 2006, 01:39pm
Gilesy,
Hoe you thinking of fitting the sierra trigger wheel to the damper? its just I'm looking at this at the moment
Cheers
Udo
UDO
Next
Users browsing this forum: Google [Bot] and 25 guests
