Minifinity The Classic Mini Forum and Resource | • View topic - Windscreen seal
Windscreen seal
tuning, repairs, servicing & maintenance
Windscreen seal
Postby Daveywantsaparty » Sat 24th Aug 2019, 08:17am
Hi guys,
Sorry, I've been a poor participant of this forum I know. I just don't seem to get any time to do anything at the moment. The kids only 14 months and he has taken over our lives...
Anyway, after 10 months of glorious mini ownership the mot came up. I decided to replace the windscreen seal as there was a minor leaking issue but have a quick question about it; do you need to remove the engine and brace the car when you are fitting a wide filtch repair panel? If so how would you brace it?
Cheers,
Dave
User avatar
Daveywantsaparty
Drives: Ford Fiesta titanium MP140
Re: Windscreen seal
Postby Nozzle » Mon 26th Aug 2019, 09:29am
I didn't remove the engine, the front subframe works as an adequate brace. You will need to remove the upper dash rail cover if it has one though. And also peel back all of that foam sound deadening, and get rid of any dust and grime which will go up in flames if caught by a weld spark/blob. I started off with CO2 pub gas which was terrible, don't waster your time with it on thin panels - go Hobbyweld Argon/CO2 mix or similar.
After you've welded, use Tiger seal in all the right places and spray in some Galvafroid/Zinc 182 on the underside/boxed sections afterwards.
Nozzle
User avatar
Nozzle
Contributor
Contributor
Drives: 1995 Rover Cooper SPi
1966 Morris Countryman
Re: Windscreen seal
Postby Daveywantsaparty » Mon 26th Aug 2019, 07:17pm
Any pictures of the filtch panel itself? Is it seam welded around the bottom? The inner side will obviously be seam while and the top and hinge panel spot welded?
There is also a chance that the hinge panel will need replacing in some places. If this were to happen so I need to brace?
User avatar
Daveywantsaparty
Re: Windscreen seal
Postby Nozzle » Tue 27th Aug 2019, 05:36pm
I'm not particularly proud of these welding jobs as it's not very neat, but they cleaned up okay. you get the gist of the panel layouts - obviously the wings were cut off too. I didn't have the engine out for any of this. Use correct sized bolts through the hinge bolt holes to maintain alignment. I splurged a load of gravitex on afterwards
Nozzle
User avatar
Nozzle
Contributor
Contributor
Re: Windscreen seal
Postby Nozzle » Tue 27th Aug 2019, 05:38pm
I found the drivers side needed some of the floor replacing too
User avatar
Nozzle
Contributor
Contributor
Return to Mechanical
Users browsing this forum: Majestic-12 [Bot] and 8 guests
cron
