Minifinity The Classic Mini Forum and Resource | • View topic - Brake bleeding problems
tuning, repairs, servicing & maintenance
Postby Mayhem » Fri 7th Sep 2018, 05:37pm
Hi all
I've recently replaced the entire braking system with new pipes and wheel cylinders and bought a repair kit for the dual system brake master cylinder which I've fitted. There are no leaks anywhere but when I try to bleed the system all I get is a spongy pedal that hits the floor when pressed. I've undone the lower 1/2" pipe connector on the master cylinder and fluid pumps out ok. But when I do the same on the top one no fluid comes out. Any ideas? It's a non servo mini if that helps.
Thanks
Mayhem
Drives: 1979 Austim Morris Mini 998cc in rustic brown
Re: Brake bleeding problems
Postby Zippyrude » Fri 7th Sep 2018, 07:10pm
did you follow the correct bleeding sequence?
User avatar
Zippyrude
Contributor
Contributor
Tag Line: Help support Minifinity
paypal@minifinity.com
Drives: projects galore
Postby Mayhem » Fri 7th Sep 2018, 08:52pm
Yes but still no joy. There is nothing happening and brake fluid reservoir not going down whatsoever when the pedal is pressed no matter how many times I try.
Thanks
Mayhem
Postby asahartz » Sat 8th Sep 2018, 11:13am
You've pretty much answered this yourself by saying no fluid comes out from the top union of your master cylinder. Something is wrong there. As you have fitted a repair kit, I can only guess that you have either done something wrong or missed something during this process.
Unpleasant as the job may be, I'd say the master cylinder needs to come off again for a strip down and recheck.
User avatar
asahartz
Contributor
Contributor
Tag Line: Slow down for bends? Why?
Drives: 89 Mini Sky, 71 Mini Clubman, 04 Audi TT V6
Postby Mayhem » Sat 8th Sep 2018, 01:07pm
Thanks for the replies. I think I will remove the master cylinder again and get another kit and try again and see what happens. Ive looked in the Haynes manual as a guide but it's not very helpful. When I stripped the cylinder down I just copied how it was before stripping when putting back together. Out of curiousity how would I know if the valve bias/compensator is faulty?
Thanks
Mayhem
Postby Mayhem » Sun 9th Sep 2018, 06:20pm
All sorted now. Was a simple case of air trapped in the master cylinder which I did a bench bleed to solve it.
Thanks for your help guys.
Mayhem
Postby Nozzle » Mon 15th Oct 2018, 09:35pm
Nice work, glad it is solved.
Nozzle
User avatar
Nozzle
Contributor
Contributor
Drives: 1995 Rover Cooper SPi
1966 Morris Countryman
Return to Mechanical
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 36 guests
