brake light switch
brake light switch
Postby modified_studio2 » Wed 1st Aug 2007, 10:18pm
after having a motorcyclist warn me yesterday that my brake lights didnt seem to be working i have started to investigate what the problem is and i think Ive figured it out but throught id run it past you lot before purchasing parts.
The car is a 1966 mk1 and the problem is that the brake lights only seem to work when the pedal is pushed hard all the way down, under normal/light braking the lights dont operate at all. Im asuming the cause of this is a faulty brake light switch which is situated in the brake line on the front subframe.
Heres a link to the part http://minispares.com/Product.aspx?pid=36731
So does the problem im experiencing sound like faulty switch? and if so is replacing the switch easy? When i undo the switch will this cause brake fluid to leak out and will i have to bleed the system?
Thanks
modified_studio2
RE: brake light switch
Postby minimaniac » Wed 1st Aug 2007, 11:32pm
It does sound like a faulty switch but before you buy one remove the wires from the switch and connect them together. The brake lights should work (with the ignition on). If they do it's the switch. If they don't then it's a wiring / fuse / earth/ bulb etc problem.
You will need to bleed the brakes if you change the switch but if you fill the master cylinder to the top and then put a plastic bag over the filler and screw the cap on (to block the vent in the cap) the amount of fluid lost should be minimal and a quick bleed should be all it needs.
minimaniac
Has thanked: 1 time
Been thanked: 11 times
Tag Line: My ambition is to have enough time to get bored!
Drives: Nothing less than 20 years old!
Postby robileeson » Fri 3rd Aug 2007, 05:14pm
i had a similar problem on my 1992 city, not sure if its the same type of switch but on mine i loosened off the nut, and adjusted the switch accordingly until the brake lights came on when they were supposed to, and then tightened the nut again.
robileeson
Postby Mk1Jim » Fri 3rd Aug 2007, 05:31pm
yeah not as easy as that on the older cars :P
Mk1Jim
Tag Line: Drive it like you own it!
Drives: Golf GTI 16v
89 Mini City
67 Morris Mini Minor SDL
Users browsing this forum: No registered users and 11 guests
