Clubman Cylinder head installation
Hi All,
Thought i would show you my next plans for my 1980 Clubman called Sheldon.
I have just bought a Hill climb race cylinder head. I will be putting it in this weekend and so far i have cleaned it and painted it.
please have a look at the photos.
The spec is as follows..
37mm inlet valves
32mm Exhaust valves
Fully ported on both inlet and exhaust
Twin valve springs (180 lb to suit your application)
Alloy valve caps
Fully worked chambers
21cc
Bronze guides
Offset exhaust valves (0.050") for better porting
and more room between valves
Pushrod holes sleeved on inlet ports
Valves freshly reground
Drilled for 11 studs
37mm inlet valves
32mm Exhaust valves
Alloy valve caps
21cc
Bronze guides
- stoppy
- Drives: 1980 Mini Clubman 1275gt (Sheldon)
Re: Clubman Cylinder head installation
A picture of the clubman from earlier this year during the winter. (there is a tube full of hot water to unfreeze the doors and windscreen
- stoppy
Some more bits have now been added before i install it tomorrow.
- stoppy
Users browsing this forum: No registered users and 1 guest
